DesignSeries02469.pngRemoving wall breaks
Tool
Tool set
Remove Wall Breaks
Building Shell
The Remove Wall Breaks tool cleans up any wall breaks or gaps that were created during editing. For example, if you create a new wall that joins an existing wall, and then later delete the new wall, a break in the remaining wall displays at the joint. The Remove Wall Breaks tool removes the break and any end caps.
To remove wall breaks:
Click the tool.
Alternatively, right-click on the wall and select Remove Break from the context menu.
Click and drag to create a marquee box around the wall break or end cap to remove.
The wall break or end cap is automatically removed.
Reshaping walls
Joining walls
Joining walls with the Fillet tool
